Author: Subject: 4 pot kits
ady8077
posted on 23/3/05 at 10:40 PM Reply With Quote
4 pot kits
Hi Mark
Any news on those pictures you said you'd email?
Adrian
marc n
posted on 24/3/05 at 07:46 AM Reply With Quote
hi adrian
unfortunately my old digital camera has finally given up ( has lasted 5 years ) hope to get it replaced in the sales this weekend then can forward you some pics of the conversion on the car
best regards
marc
GrahamC
posted on 7/4/05 at 01:54 PM Reply With Quote
Brakes
Marc - you have U2U.
What's happening with the brake update?
marc n
posted on 8/4/05 at 12:39 PM Reply With Quote
the brackets are at the anodisers as we speak hopefully recieving them back on wednesday / thursday will post picture then
best regards
marc
marc n
posted on 14/4/05 at 06:57 AM Reply With Quote
hi all brake conversion kits are due to arrive today these will allow you to use the larger vented disc that most sierras come with rather than the 1600 solid disc by means of spacers
hope to have a picture uploaded to our website by the weekend
best regards
marc
ady8077
posted on 28/4/05 at 06:35 PM Reply With Quote
Hi Marc
Any news?
Will they be on show at Stoneleigh ?
Adrian
marc n
posted on 29/4/05 at 07:07 AM Reply With Quote
yep there will be a caliper and bracket at the show this setup allows you to use the vented discs which im sure most people will have alraedy rather than having to change to a solid
best regards
marc
ady8077
posted on 29/4/05 at 07:03 PM Reply With Quote
Thanks Mark
See you at the show
Adrian
ady8077
posted on 10/5/05 at 06:39 PM Reply With Quote
Hi Mark
Had a look at the show, didn't get chance to talk as you were busy and i was running late, thought the conversion looked very neat
Only thing that puzzles me is how you can use sierra disks, I thought the calipers could only use up to 22mm thick disks?
Also do they use the same hose fittings?
Adrian
marc n
posted on 10/5/05 at 08:38 PM Reply With Quote
ahhh
a new bracket we have made gets the correct spacing and a spacer kit in the caliper gives the width saves using the solid ones from rally design that have new holes drilled in them as they should fit a golf
