andy d (rizla)
posted on 26/6/05 at 11:27 AM |
tyre pressures
just a quick question,(mk boys may be able to answer) what sort of tyre pressures should i be looking at on the blade vortx,the tyres are 195 50 15
yokohamas and the weight of the car is 420kg
ta very much
Jon Ison
| posted on 26/6/05 at 11:36 AM |
20-21psi when run up too temp, on a warm day on track prob need about 17-18 to allow for pressure pick up.
andy d (rizla)
| posted on 26/6/05 at 11:41 AM |
thanks jon,ive got them set at 20 at the mo,just wanted confermation realy thaks very much
Jon Ison
| posted on 26/6/05 at 12:23 PM |
what you need too do is give them a good work out, jump out and check pressures ASAP starting at 20 you may bit a tad over.
andy d (rizla)
| posted on 26/6/05 at 12:36 PM |
will do jon,another excuse to go for a blat
