Dillinger1977
| posted on 14/8/05 at 07:41 PM |
fuel pump location
just furtling with the R1 fuel pump at the moment, found a nice location for it and just wanted to check it was okay..
i got rid of the floppy rubber surround and am now using a foam lined circular clamp.
the only thing that bothers me is that its just slightly lower than the floorpan of the car. i dont know if theres any chance of anything hitting it,
but would it be better to tuck it away a bit more or is it okay where it is?.
side:
top:
cheers!
-Rog
MkIndy7
| posted on 14/8/05 at 07:45 PM |
Could you not mount it on the side of that chassis member instead of underneath it?
It might protect it a bit more and shouldn't be 2 hard to do with some short flexis
marc n
dont put it below the floor pan,
put as per build manual options, stays out of harms way
best regards
marc
shortie
| posted on 14/8/05 at 07:51 PM |
I would definitely put it above the floor plan, much less chance of it getting hit by anything.
Rich.
Dillinger1977
| posted on 14/8/05 at 07:55 PM |
cheers chaps, what would i do without you? (apart from make an a**e of it! )
have you got any huge p-clips lying about marc? (the one in the manual) i couldnt find any at the show
[Edited on 14/8/05 by Dillinger1977]
-Rog
Dillinger1977
| posted on 14/8/05 at 08:29 PM |
would this be better?
its a wee bit higher than the fuel outlet from the tank..
-Rog
