Author: Subject: silcone hoses at great prices
marc n
posted on 25/8/05 at 09:53 AM Reply With Quote
new range of silcone hoses coming soon, in yellow, purple, green, red, blue, orange, black
from 9mm id to 127mm id
90
45
135
t peices
reducer hoses
reducer elbows
hose joiners
details will be on our website middle of next week under cooling
10 % disconut on all oredrs to locost builders
dont forget we can also provide steel cooling pipes bent to your spec powder coated
best regards
marc
[Edited on 25/8/05 by marc n]
suparuss
posted on 25/8/05 at 04:16 PM Reply With Quote
ooh, never heard of you guys. ive been looking for someone to buy me polybushes from instead of gts! bit in the dark ages yer site though, no online ordering!
suparuss
posted on 25/8/05 at 04:29 PM Reply With Quote
bloody cheap though! i have a quiestion- do you know the weight per meter of the 35mm cds you use for roll cages, mild steel and the t45. also- what is t45? can i weld it normally to steel?
Russ.
Winston Todge
posted on 25/8/05 at 04:31 PM Reply With Quote
You really are going all out aren't you Marc!
Are these made by Samco or by a local supplier? More cost effective (the girlfriend likes me to use that phrase...) than the Samcos?
Chris.
[Edited on 25-8-05 by Winston Todge]
NS Dev
posted on 25/8/05 at 10:32 PM Reply With Quote
Russ.
for steel tubing (any "normal" steel alloy grade) weight per metre is = ((OD-Wall)xWall)x0.02466
saves Marc a job!
suparuss
posted on 26/8/05 at 05:31 AM Reply With Quote
it doesnt say on the site what wall thickness is. i couldnt see it anyway.
marc n
posted on 26/8/05 at 12:08 PM Reply With Quote
we only use 1 3/4 2.64mm cds as required by the msa for competition use on all our cars road and race
t45 is increadibly strong so you can use a thinner wall to acheive the same tensile strength as cds but of course you end up with quite a weight saving on a full rear cage, t45 is slihtly tricky to weld as opposed cds, but easily acheivable with a good mig and the correct gas ( crysal )
best regards
marc
