Howlor
| posted on 7/10/05 at 11:09 AM |
Seat Mounting & Harness Holes
After reading the SVA manual I have some idea but as per usual it is a little vague. I am at the stage were I need to cut the harness holes in my GRP
seats and then mount my harnesses. What are the main areas to consider. I understand that the harnesses are not allowed to touch the seats unless the
seat is a stressed component?
Do the harnesses need to be a certain height above the shoulders?
Any help or failure woes will be of use!
JAG
| posted on 7/10/05 at 12:19 PM |
There is a minimum height for the belt holes above the seat base. The SVA Inspector will use a special tool (with spirit level and bits of string
etc...) to measure this.
I had a problem with the upper belt mounting being too low. This can cause spinal compression in an accident and so they insist upon a certain height
above the seat.
Check my photo archive for the solution I used.
Justin
Humbug
| posted on 7/10/05 at 05:02 PM |
above the seat.
How is your bracket fixed to the rear crossbar thingy? Is it just bolted down with the seat belt bolt?
also, are your boltholes threaded, i.e. the nuts are just for extra security, or are the nuts the only method of holding the bolts on? I ask because I
thought the SVA manual says that you have to be able to undo the bolts without access to the other side of what they are bolted to.
