Howlor
posted on 24/10/05 at 11:16 AM |
MNR Fuel Tank - Return Pipe / Tank Vent
I am running a carbed Blade unit therefore I have no need for the return fitting near the filler neck on the MNR ally tank. Should I just blank this
off or is it wise to use this as a vent to avoid a vacuum in the tank. If so what is the best way of doing this?
marc n
posted on 24/10/05 at 11:20 AM |
yep use that as a vent with a suitable one way valve enables much quicker fuelling,
and for the benefit of other builders
when running fuel injected use that outlet as a return then use a vent pipe in the filler neck
best regards
marc
Howlor
posted on 24/10/05 at 12:02 PM |
Thanks Marc.
