amalyos
posted on 6/11/05 at 07:38 PM |
wheel offset
What type of offset should I use with the MNR?
What does the ET mean when quoting the offset?
cheers,
Steve.
G.Man
posted on 6/11/05 at 10:41 PM |
ET is the distance off centre the wheel flange is...
For 6 inch wheels you want an ET35 offset for the road and an et18 peugot odffset for the track..
The larger the offset the closer the wheels to the cycle brackets...
[Edited on 6/11/05 by G.Man]
Opinions are like backsides..
antonyg
posted on 6/11/05 at 10:51 PM |
this website explains offsets and pcd
also has all make of car and what offset wheels they use
http://www.alloyguide.co.uk/PCD.htm
mookaloid
posted on 6/11/05 at 11:32 PM |
good link that
Rorty
posted on 7/11/05 at 06:20 AM |
What a complete tw4t! He says (among other humerous remarks) "OFFSET (also referred to as 'ET': Simply this is where the outside of
the wheel needs to be in relation to the bodyline of the vehicle"
And this absolute screamer "Detailed Explanation: There are 2 main reasons for fitting Alloy Wheels: Weight and Style. Alloy wheels are a lot
lighter than the equivalent size of steel wheels."
Cheers, Rorty.
mnr laptop
posted on 7/11/05 at 10:41 PM |
hi steve
for the rt+ et18
best regards
marc
GregMcN
posted on 13/11/05 at 08:46 PM |
How about 7 inch wide wheels with 35mm offset on a RT?
Greg
