amalyos
posted on 2/1/06 at 09:14 PM |
R1 loom to MNR loom connections?
Does anyone have details of the connections I have to make between the R1 loom and the MNR custom loom?
I don't think there are many, mainly sensors and indicators (i'm using the R1 clocks), but the main area I need some help is with the
ignition, as I'm using the Sierra ignition switch.
A diagram would be great if anyone has one.
smart51
posted on 3/1/06 at 08:09 AM |
I have connected both looms straight to the battery. That's power and ground sorted.
You will need to connect the crank from the sierra key switch into the bike's ignition. The car has a switched positive and the bike a switched
negative, but don't worry. Short out the stop switch, and start switch. Cut the wire on the bike loom feeding 12V to the start relay coil and
connect your crank here.
I conneted 4 more wires, all of which went to the "headlight" sub loom that connects to the clocks. The wires were sidelights (for the
clock back light), Main beam warning, indicator L and R.
Simple.
amalyos
posted on 3/1/06 at 11:08 PM |
Sorry to be a bit thick, (not very good with the electrics), but I don't have the start switch, stop switch, and not sure which cable to cut for
the starter relay coil.
Could you identify the cable colours for me so I can match it up with the R1 wiring diagram.
Steve.
smart51
posted on 4/1/06 at 08:12 AM |
I have closed the start, stop, clutch and side stand switches by soldering the two wires together. I left the main switch open and removed all the
lights. A resistor in place of the fuel level sensor stops the low fuel light comming on.
BTW, this drawing is not guaranteed to be right.
[Edited on 4-1-2006 by smart51]
amalyos
posted on 4/1/06 at 11:44 AM |
Thanks for the diagram, it does simplify the diagram from the manual. I'll have a good look over it tonght.
Cheers.
amalyos
posted on 5/1/06 at 10:41 AM |
The diagram did simplify the R1 Haynes one. I have now created a basic diagram showing the connections to the MNR loom. Just hope it works when I get
it in the car!!
Thanks again.
Dillinger1977
posted on 5/1/06 at 01:15 PM |
it in the car!!
Thanks again.
hope it works! post a photo/diagram when you're done. i havent got to this stage yet and it all reads like hebrew to me.
-Rog
amalyos
posted on 5/1/06 at 03:22 PM |
I know what you mean, i've spent a few evenings on the manuals, but I think it makes sense now!!!
It will be a few months before I get to fire her up, but if you need it before let me know.
Steve.
RichieC
posted on 5/5/06 at 04:40 PM |
Just posted over in BEC regarding this, Smart51 do you have a better copy of that pic you drew please so I can make out the smaller print.
Thanks and Rgds
Richie
