RichieC
| posted on 8/1/06 at 05:31 PM |
Which Samco Hoses - R1 Vortx & Polo Radiator
Evenin all,
Can anyone tell me which hoses I need with a Polo Rad and R1 engine please.
I understand the Polo rad is 32mm and the R1 in 25mm but specifically which hoses do I need? Obviously a 32-25 convertor but what else,
Thanks in advance
Kind Rgds
Richie
[Edited on 8/1/06 by RichieC]
mnr laptop
| posted on 8/1/06 at 06:53 PM |
hi ritchie
you will need 2 x 90 degree 32mm, 1 x 90 degree 25 - 32mm reducer , 1 x 32 - 25mm straight reducer, 1 x 45 degree 32mm
best regards
marc
RichieC
| posted on 8/1/06 at 06:55 PM |
Thanks Marc, I take it there are some aluminium tubes required aswell? And a length of smallish diameter tube to the header tank.
Thanks again
Rgds
Richie
Dillinger1977
| posted on 8/1/06 at 10:13 PM |
heres what ive got so far. i havent done any teeny-tiny hoses yet, just getting the bigger bore stuff in.
b&q do a 1m length of 32mm alu pipe , and a length of 25mm with a Z shape (ideal!). 6 and 4 quid i think. (tv section)
ive still got to look about for some of the hose to connect the oil cooler to the T-Piece., as the r1 hose is too short. (oh, i got the t-piece from
MNR)
  initial plumbing
[Edited on 8/1/06 by Dillinger1977]
-Rog
RichieC
| posted on 8/1/06 at 10:41 PM |
Thanks Rog, thats very useful.
Ingenious with the TV aerial poles Ill pick them up next time Im in.
Itll be a metal T piece your using for the T off to oil cooler is it?
Looks like youve used a slightly different configuration than Marc, am I right you have:
2 x 32mm 90 degree
2 x 32-25 straight reducers
1 x 32mm 45 degree
Rgds
Richie
Dillinger1977
| posted on 8/1/06 at 11:01 PM |
yep thats pretty much it so far. i guess if you can get a 90 degree reducer that'd cut down on having the bend+reducer seperate.
i did write down the size of the hose needed for the oil cooler today but ive lost it laready (doh!)
the t-piece is metal, yup.
cant take credit for the tv ariel idea im afraid, someone else on the forum had that gem of wisdom.
(guinness + colibriman) : http://www.locostbuilders.co.uk/viewthread.php?tid=31746
-Rog
RichieC
| posted on 8/1/06 at 11:06 PM |
Yeh, you can get a 90 degree 32-25 and that would help. I wonder where Marc used the other 32mm 90 degree then.
Rich
