GregMcN
posted on 26/2/06 at 09:04 PM |
Reverse gearbox
Sounds like a stupid question but how do you fill it with oil!
Only a very small hole in the filler so presume you have to to remove one of the side fittings to let air out - but which one?
Cheers Greg
mnr laptop
| posted on 26/2/06 at 10:15 PM |
the filler plug is the silver hex bolt on the side, it has a vent orange one on top, best bet is an old washing up liquid bottle with a piece of tube
and pump the oil in, or remove breather cap and fill from the top
best regards
marc
pk
| posted on 27/2/06 at 01:23 PM |
reverse box
i had problems with mine see this post for info obout the vent tube you will need.http://www.locostbuilders.co.uk/viewthread.php?tid=30394
marc n
| posted on 27/2/06 at 04:12 PM |
yep breather needs extending, should be able to get a male male adeapter and a 90 degree fitting to let you run a pipe into the breather pot from any
agricultral engineers etc, if not you end up with oil everywhere the first time you use it !!!, with the breather pipe fitted never had a problem
best regards
marc
