Krismc
| posted on 24/3/06 at 04:22 PM |
Which Hand Brake cable do i require??
Which Hand Brake cable do i require for my vortx, ford parts do 3 or 4 types?
And who supplys them?
and do i need any brackets or anything made up to fit to the handbrake end?
mike smith1
| posted on 24/3/06 at 04:27 PM |
Depends on what brakes you are running on the back end, discs or drums.
You need to get the specific cable for either, then shorten it, you can buy a fastening for the end.
HTH Mike
DarrenW
| posted on 24/3/06 at 04:34 PM |
I used allegro cables for my drum rear. Originally had one piece sierra cable that was cut and clamped at the handbrake end but fell foul of Mr SVA.
They should pass now but Allegro seems fine. Supplied by Mac#1.
Dillinger1977
| posted on 24/3/06 at 05:41 PM |
handbrake cables cant be clamped for sva?
-Rog
Krismc
| posted on 24/3/06 at 10:02 PM |
quote: Depends on what brakes you are running on the back end, discs or drums.
HTH Mike
Disks my friend, and a fastening from where- you got any pics!
Krismc
| posted on 24/3/06 at 10:03 PM |
quote: handbrake cables cant be clamped for sva?
so they just fixed at either end??
P.S you got a vortx build manual yet- im finding this difficult with out one??
RazMan
| posted on 25/3/06 at 12:21 AM |
Available from MK I believe
Raz
Krismc
| posted on 25/3/06 at 09:43 AM |
quote: Available from MK I believe
cheers,
ps you drinking when you took that pic
RichieC
| posted on 25/3/06 at 12:37 PM |
Kris,
You need a bog standard Sierra cable for any model with disc brakes and a quadrant from MNR. The cable inner is cut at the lever end, quadrant
attached and the cables are then clamped back onto themselves with wire rope clamps (MNR or B&Q).
There has been discussion about the SVA-ability of rope clamps but they are fine. Theres no need to mess about with the caliper end of the cable, or
use a different cable from a different supplier.
Rgds
Rich
Krismc
| posted on 26/3/06 at 10:12 AM |
Kris,
i better ask for a quadrant then cause it aint in with the kit,
The cable inner is cut at the lever end, quadrant attached and the cables are then clamped back onto themselves with wire rope clamps (MNR or
B&Q).
Dont worry i have loads- i actually gave MNR some- i use them at work!
yea they should be too cause i fix lifts for a living and thats all thats holding them up!!! ha ha
Theres no need to mess about with the caliper end of the cable, or use a different cable from a different supplier.
Rich
cheers mate that sounds too easy
Krismc
| posted on 27/3/06 at 03:57 PM |
WHERE CAN I GET A BOG STANDARD CABLE THEN FOR LESS THAN THE £41 QUOTED BY FORD PARTS
NS Dev
| posted on 28/3/06 at 09:41 AM |
your local motor factor, £15-£20, mine was £18 iirc from Central Auto Supplies, my usual motor factor in Hinckley.
DarrenW
| posted on 28/3/06 at 01:34 PM |
I paid 16 / 17 quid for mine from mac#1. most motor factors should have them.
Ref cable clamps i have been told that a bulletin has gone round Vosa test centres to say clamps are now OK. it was me that had a major issue in
December at Gosforth which led to an investigation. Hopefully all centres are now reading from the same rules. If in doubt ring up and confirm. You
need 2 clamps on each side of the quadrant iirc. (4 in total). Well overkill i know but i guess safety is key.
