Author: Subject: RADIATOR FITMENT!!!
Krismc
posted on 26/3/06 at 07:46 PM Reply With Quote
RADIATOR FITMENT!!!
DOES ANYONE HAVE A BETTER PICTURE<
Because if i fit my radiator as below where i am holding it!!, i have a weld below each bracket? is this in the right spot and how have other people fixed theres??
[Edited on 26/3/06 by Krismc]
amalyos
posted on 26/3/06 at 08:04 PM Reply With Quote
I had a similar problem, I ended up putting the rad at a bigger angle than in the manual, in order to get hose clearance.
I think it should be OK, but not tested yet.
Steve.
amalyos
posted on 26/3/06 at 08:06 PM Reply With Quote
There are some Pics in my archive.
Ignore the fan ties, they need to be changed.
Krismc
posted on 26/3/06 at 08:22 PM Reply With Quote
cheers ill take a look!?!
... had a look, did you just rivot the bracket to the chassis? and im sure that angle should be fine!
Dillinger1977
posted on 27/3/06 at 08:15 AM Reply With Quote
i used rivnuts to fix the upper brackets and made little plates to rivet the lower mounts.
looks like you have a tube upper chassis rail which might make rivnuts pretty hard to use.
i had to angle the lower mounts away from the chassis enough to get a 90 degree silicone hose bend in there.
-Rog
Krismc
posted on 27/3/06 at 03:58 PM Reply With Quote
cheers i better get a bit of pipe to see how it fits first!!
