Author: Subject: SPROCKET NUT
Robert Ryan
posted on 5/4/06 at 08:36 PM Reply With Quote
SPROCKET NUT
I have tried to tighten the nut onto the new engine sprocket before putting the crank shaft on, but cannot get a socket in as the socket is to wide and will not go inside ths sprocket to tighten the nut.
Anyone know how.?
[Edited on 5/4/06 by Robert Ryan]
[Edited on 6/4/06 by Robert Ryan]
[Edited on 13/4/06 by Robert Ryan]
posted on 5/4/06 at 09:27 PM Reply With Quote
i managed to get my impact wrench in via the transmission tunnel. Is yours too far over for this? not a vortex obviously...
[Edited on 5/4/06 by JoelP]
smart51
posted on 6/4/06 at 07:05 AM Reply With Quote
try a spanner end on, the tapered ends should fit into the hole.
I used an adjustable spanner on the nut and another on the first spanner to turn it. It was a bit heath robinson but it worked and nobody say me.
ChrisGamlin
posted on 7/4/06 at 08:56 PM Reply With Quote
You might want to look for a suitably sized box spanner as they generally get in to tight areas where a socket can't. Either that or ask a friendly machine shop to turn your socket in their lathe and skim the outside down a bit, although obviously it will weaken it excessively if you do it too much!
marc n
posted on 10/4/06 at 08:12 AM Reply With Quote
i have a machined down socket, you can borrow if you like
best regards
marc
Robert Ryan
posted on 10/4/06 at 04:36 PM Reply With Quote
Thanks mark ill pick it up next time I come up.
Robert Ryan
posted on 13/4/06 at 03:50 PM Reply With Quote
I have found a socket at Halfords £7
Job sorted.
Krismc
posted on 13/4/06 at 08:46 PM Reply With Quote
Good old hellfrauds, cough cough i mean halfords!
Winston Todge
posted on 24/5/06 at 09:04 AM Reply With Quote
What size socket does the sprocket nut require and what's the easiest way to get enough torque onto the nut whilst stopping the motor turning over?
Ta,
Chris.
RichieC
posted on 24/5/06 at 11:25 AM Reply With Quote
Just as an aside, its 85NM torque for the sprocket nut with tab washer.
Rgds
Rich
marc n
posted on 24/5/06 at 05:41 PM Reply With Quote
cant remember of the top of my head but will check tomorrow and post here
please email rather than u2u
chrismnrltd@btinternet.com
marc n
posted on 24/5/06 at 05:42 PM Reply With Quote
can send you it in the post if it helps to borrow, mine has been machined specially
