Author: Subject: Gear lever
JoaoCaldeira
posted on 9/4/06 at 01:59 PM Reply With Quote
Gear lever
Hi all.
I've put the gear cable as further as possible, but even so the bearing eye is not aligned with the lever moutings (in the pic, the cable is half way of it's travel).
What am I doing wrong?
Should I cut the rodend thread? (would just gain half of what I actually need)
Thanks,
ReMan
posted on 9/4/06 at 02:13 PM Reply With Quote
Move the gearlever stub round by one spline on the gearbox shaft?
smart51
posted on 9/4/06 at 02:46 PM Reply With Quote
move the gearshift arm round a few splines or move whatever holds the gear cable outer, at the gearbox end, away from the gearbox.
You should not cut the threads off the cable.
marc n
posted on 10/4/06 at 08:09 AM Reply With Quote
you can cut some of the threads of the bar no problem then rotate the lever on the engine end, you need about 15mm of cable travel to get the required movement
best regards
marc
JoaoCaldeira
posted on 10/4/06 at 08:17 AM Reply With Quote
Hi all.
Thanks for your replys. Sorry for my english, but I'll try to explain better...
As I see it, the problem is not in the gearbox side (actually, the engine isn't even there), as the problem is the position of the rodend and the gear lever side.
In the pic, the cable is halfway of it's full travel - where it should be when resting. If I need half of it's travel to push and the other half to pull this should be the dead center, and where the lever would be vertical.
If I put the lever now it would be inclened to the front, as the rodend passed the lever mounts.
The rodend it fully tightned but a few threads are still present. May I cut them? - even so it would half of what I need...
Joao
JoaoCaldeira
posted on 10/4/06 at 08:32 AM Reply With Quote
Thanks Marc.
I didn't saw your reply when I wrote mine...
I'll check that solution late rwhen I get home.
Thanks,
Joao
Winston Todge
posted on 10/4/06 at 09:27 AM Reply With Quote
Is that a TRT under the clutch cable Joao?
Or is that usually in the rear of the propshaft?
Chris.
JoaoCaldeira
posted on 10/4/06 at 01:11 PM Reply With Quote
I must confess that I donno...
Just ordered a regular 2 piece prop....
Joao
