Author: Subject: alloys what ET
scoey m
Builder
Posts 209
Registered 8/2/06
Member Is Offline
Photo Archive Go!
Building: MNR Vortx r1(sva pass 07 plate yumyum)
posted on 2/5/06 at 05:18 PM Reply With Quote
alloys what ET
Hi all
just quick question what ET offset have people used for their vortx and what would you recommend
Managed to get some team dynamics pro race 2 in 16" 479.99 for full set ,but 3 weeks waiting will becoming straight from factory so will be made to spec i require
G.Man
posted on 2/5/06 at 05:40 PM Reply With Quote
You checked the MNR FAQ right?
Opinions are like backsides..
scoey m
Builder
Posts 209
Registered 8/2/06
Member Is Offline
Photo Archive Go!
posted on 2/5/06 at 05:47 PM Reply With Quote
of course they recommend ET35 but seen people using ET38 just want to check what others are using
Krismc
posted on 2/5/06 at 05:51 PM Reply With Quote
ET38 on 15,195's on a Vortx Plus
scoey m
Builder
Posts 209
Registered 8/2/06
Member Is Offline
Photo Archive Go!
posted on 2/5/06 at 05:55 PM Reply With Quote
Is their a difference between rt/rt+ to what offset you require
flak monkey
posted on 2/5/06 at 05:57 PM Reply With Quote
ET35 and ET38 will make no noticeable difference. You will get all of 3mm track difference.
ET38 is std sierra offset, thats probably why most people use it. ET19 is the offset of the older rwd fords (escorts, cortinas and capris). But as the MNRs are sierr based ET38 will do you just fine.
Sera
http://www.motosera.com
Krismc
posted on 2/5/06 at 06:15 PM Reply With Quote
my wheels sit in very tight at the rear with Et 38 so anything between Et19 and 38 will be ok i assume!
chockymonster
posted on 2/5/06 at 06:37 PM Reply With Quote
ET35 for an RT
ET18 for an RT+
Asked Marc the same question last week.
scoey m
Builder
Posts 209
Registered 8/2/06
Member Is Offline
Photo Archive Go!
posted on 2/5/06 at 08:17 PM Reply With Quote
excellent guys thank you very much
rjbrookes
posted on 2/5/06 at 08:39 PM Reply With Quote
i got.....
ET 24 for front 185/60 R13
and
ET 24 for rears 205/60 R13
RT+
russ
G.Man
posted on 3/5/06 at 03:56 AM Reply With Quote
ET38 is the equivalent of ET35 on a wider wheel... gives more clearence on the inside edge
Both ford offsets..
ET 35 for 6.5 inch, ET38 for 7.0 inch
ET 18/19 is Peugot offset or some older fords with narrower wheels..
