Author: Subject: Handbrake cable!
Krismc
posted on 29/5/06 at 08:44 PM Reply With Quote
Handbrake cable!
Where have people ran there handbrake cables, mine seems to rub a lot where ever i put it!!
and the brake flexis seem a little long too???
RichieC
posted on 29/5/06 at 10:23 PM Reply With Quote
Im on drums so not much help, but with the flexis, secure the caliper/drum end and put a twist in them to use up slack and keep them clear of anything which might contact them.
Rgds
Richie
Krismc
posted on 30/5/06 at 06:00 PM Reply With Quote
done that but they will rub eventually
marc n
posted on 31/5/06 at 09:48 AM Reply With Quote
if you are worried that it is not securely fastened enough use some rubber pipe over the cable to stop rubbing, rear flexis are long to give a nice sweep round so they connect well out of the way of the wheel and heat from the brakes etc
please email rather than u2u
chrismnrltd@btinternet.com
Krismc
posted on 31/5/06 at 05:43 PM Reply With Quote
Ah right i must have mine in the wrong place, and yes ill do that with handbrake!!
cheers marc
