Author: Subject: How and where did you fix the tub / bodywork
JoaoCaldeira
posted on 8/7/06 at 10:42 PM Reply With Quote
Hi VortX builders.
How and where did you fix the tub / bodywork?
have you riveted the bottom? have you used washers to spread the load?
Thanks in advance,
Joao
marc n
posted on 9/7/06 at 10:27 AM Reply With Quote
hi joao
i use six rivets on the bottom one at front one at middle and one at the back near where the seats fix, the top does not need fixing as your scuttle panel and nosecone bolt straight through the top edge, i know some people have glued them on, but it can be a nightmare removing the panels if you ever have to replace them
best regards
marc
please email rather than u2u
chrismnrltd@btinternet.com
