Author: Subject: Fibreglass seat mounting
JoaoCaldeira
posted on 13/7/06 at 09:18 AM Reply With Quote
Hi all.
How have you fixed the fibreglass seat to the chassis / rails?
Which kind of bolt have you used? (I don't even feel confortable with the idea of having a bolt (or 4) up my bump let alone the bolt itself... )
How have you reinforced / load spread it?
Pics?
Thanks,
Joao
RazMan
posted on 13/7/06 at 12:48 PM Reply With Quote
Bighead fasteners do a range of sizes which you can bond into the seat base. Clever stuff
Raz
russbost
posted on 13/7/06 at 01:12 PM Reply With Quote
Kart seat retainers are a sort of flat headed button bolt with a flat cup around it to spread the load, even with a bony bum like mine you don't feel them underneath you at all.
Agriv8
posted on 13/7/06 at 03:55 PM Reply With Quote
button head M8 and lage washer on top, underneath i used some rubber suspension inserts. I am sure they have a name but cant remember.
Regards
agriv8
Dillinger1977
posted on 14/7/06 at 08:14 AM Reply With Quote
not sure what type of seats you have Joao, but if they are anything like mine ( completely rounded base, no flat areas) they are very awkward to mount!
i have 2 sparco side mounts like this
which seem to work rather well, but they are a bit on the heavy side, so im considering other methods.
im considering just bolting through the base as im going to make some form of cushion anyway so sitting on them shouldnt be a problem.
the only problem will be that the base is not flat so the bolt heads will not lie flat properly.
Marc suggested bending the bolt heads at an angle.
of course, if you have the later seats with a flat base you should be fine
-Rog
marc n
posted on 14/7/06 at 09:23 AM Reply With Quote
hi joao
your seats are newer style and have the threads built in as per the picture as razman has posted on here
please email rather than u2u
chrismnrltd@btinternet.com
JoaoCaldeira
posted on 14/7/06 at 03:28 PM Reply With Quote
Hi Marc...
Nope... I think I got the last batch of old seats
I saw the new ones at your place when I got mine...
Fancy an exhange?
Joao
