Author: Subject: mega squirters
graememk
posted on 25/8/06 at 09:28 AM Reply With Quote
mega squirters
as a rough guide, what do you have your fuel constants set to mine are 7.2 to get it to run ok
1.8 nissan turbo with 330 injectors
would you say thats high or low or about right. as its currently draininng iraq of petrol at an alarming rate.
graememk
posted on 25/8/06 at 10:42 AM Reply With Quote
but my eyes are bleeding from all the reading.
and now my brain hurts.
i only want to know if it sounds about correct.
Edit
"This is a case of you trying to cut corners again graeme" me do a thing like that ...... never
[Edited on 25/8/06 by graememk]
MikeR
posted on 25/8/06 at 11:44 AM Reply With Quote
sounds fine to me - but i've never read the manual or built a megasquirt (yet).
How difficult is the tunning? this is one of my worries.
paulf
posted on 25/8/06 at 01:57 PM Reply With Quote
The injector constants depend on flow rate of your injectors plus many other factors such as squirts per rev etc. Megatune should calculate its own factors if you put in the known flow rate and other factors.You also need to be reasonably near in you power and tourque inputs to generate the VE table to start with.
Have you tried datalogging it and then adjusting using the Megalog viewer software? it is easy to use. I got mine running reasonable and have been tuning it from datalogs recently and it now runs well.
Paul.
martyn_16v
posted on 25/8/06 at 08:55 PM Reply With Quote
Calculated req_fuel for your engine size and injectors is 9.1. You're better off sticking to that and using the VE table to get it running right, having an incorrect req_fuel can give you hassle later unless you know what you're doing.
I found I was using more fuel than usual at first as well. I put it down to the fact that I started well on the rich side of cautious, but pretty quickly you get to the point where you can't smell petrol being squirted out of the exhaust
ZetecVan
posted on 25/8/06 at 09:39 PM Reply With Quote
As Martyn says, stick the calculated fuel rate in there and tune the VE table using the new version of the Megalog Viewer software.
