chockymonster
posted on 8/9/06 at 08:50 AM |
Engine bay earth point
Guys,
I'm wiring up the MNR loom at the moment.
I've sorted my rear earth but I'm not sure where to mount the front earth point.
Any suggestions?
Paul
marc n
posted on 8/9/06 at 08:56 AM |
hi paul
i usually have an earth going from engine cradle mounting bolts on chassis direct to earth terminal
please email rather than u2u
chrismnrltd@btinternet.com
chockymonster
posted on 8/9/06 at 09:29 AM |
Do you then connect the front loom earth to the battery then?
posted on 8/9/06 at 09:32 AM |
the biggest current will be for the starter motor so you want fat wire gong from battery negative to the motor; usually the connection connection to
it is via the gearbox engine block so you want to connect on one of those but close to the starter. It is porbably arbitrary as to where you connect
to the chassis but obvioulsy you would use a short length of wire.
what I am trying to say is there is no single correct place but many bad ways of doing it.
chockymonster
posted on 8/9/06 at 09:35 AM |
Guess which one I'll choose then
wilkingj
posted on 8/9/06 at 02:32 PM |
I welded a lug onto the chassis, then earthed all the cables at one point.
This should be a std fitment on every chassis.
The cable lying across the picture goes to the battery. Wasn't connected when I took the picture. Other cable is from the Lug to the Bellhousing.
Sorry for the Big piccy.
Earth Lug (My Welding!!!)
Best Regards
Geoff
http://www.v8viento.co.uk
TimC
posted on 8/9/06 at 03:11 PM |
AMEN!
chockymonster
posted on 8/9/06 at 04:15 PM |
totally agree
TimC
posted on 8/9/06 at 05:04 PM |
Whoever gets my order (and it may well be MNR) will be kindly asked to do this.
