Author: Subject: Column to rack link
chockymonster
posted on 12/9/06 at 05:22 PM Reply With Quote
Column to rack link
I've just unwrapped the link piece between the column in preparation for fitting the rack.
What should I use to fix the trangular shaped end to the steering column? There are 2 threaded holes but nothing going over the top.
Danozeman
posted on 12/9/06 at 05:49 PM Reply With Quote
There should be a plate that bolts across the 2 flats. Usually one side is pivoted and bolts the other.
Dan
