amalyos
posted on 23/9/06 at 07:52 PM |
Vortxs or Vorti
What are more than 1 Vortx called?
Weather was great today, good day spent in the Essex lanes pitting R1 against Zetec.
Lots of missed gears, hitting neutral instead of 2nd, ouch.
I definately need a rejet, I can't pull above 10K
Cheers Dion, had a good day, sorry Reece for hitting the puddle (hence the mud).
Steve.
numnuts
| posted on 23/9/06 at 09:21 PM |
Hi steve also had a great day, dont worry rhys holds no grudges. Thanks again
scutter
| posted on 23/9/06 at 09:53 PM |
I love the styling of the Vortx, But still can decided if I like the full front arches,(sorry can't afford one which is why I had to build) I
must say that they could cut down on road spray no end.
Don't fret about me, just had a week on the Isle of wight with the family and am awaiting the next dry day so I can go for a drive.
[Edited on 23/9/06 by scutter]
watsonpj
| posted on 23/9/06 at 10:15 PM |
Hi Steve
car looks great.
That missing second think is a real pain, is it because you using clutch for upchanges its way less likely without. The throttle return spring at the
carb end also seemed to help a bit.
Remember after a miss the tendency is to try to bang it back in which worked for me right up until I banged the top of the gearstick off .
Hope the weather holds
cheers Pete
Agriv8
| posted on 23/9/06 at 10:56 PM |
I recon it must be votises.
the rap round mud gards are a godesend when you hit the puddles or its wet.
they stop allot of the sparay exiting sideways.
Ps well done chaps for fighting the MNR corner . should we agree on a brace of vortx ill let you two decide on which is which
All the best agriv8
Dillinger1977
| posted on 24/9/06 at 07:44 AM |
The nice thing about the full front arches is the choice. Since you start with a 'big' one, you can trim it whatever way you like, even
back down to a standard size.
-Rog
Winston Todge
| posted on 24/9/06 at 10:29 AM |
The look the mutts nuts guys!
The front arches are an aquired taste I think but apparently they help aerodynamics from the normal 7 brick...
They do help on the crap spraying front too. I'm going with full arch and then if they look a bit intrusive, put a similar black inset on the
arch as Marc has done on his Orange beast...
It'll be great when we can get a proper gaggle of VortI (another possibility?) together. May even get my engine fired up next week! Just gotta
find me a good crimping tool now...
G.Man
| posted on 24/9/06 at 10:48 AM |
I got marc to trim mine, they dont look (and aren't) as heavy that way..
Opinions are like backsides..
marc n
| posted on 26/9/06 at 06:46 AM |
well done guys they look like a great pair of vortex / vorti
please email rather than u2u
chrismnrltd@btinternet.com
chockymonster
| posted on 26/9/06 at 09:44 AM |
I do worry when the designer can't even spell the name properly
It will be nice to get a bunch of vortexeseses together :p
