chockymonster
| posted on 22/11/06 at 08:37 PM |
Throttle return spring
What's the best spring to use at the pedal end?
Winston Todge
| posted on 22/11/06 at 09:02 PM |
I nabbed one from an angle poise at work! Seems perfect!
  Spring from angle poise
Chris.
cryoman1965
| posted on 22/11/06 at 09:20 PM |
There are some good springs on the pedal set out of a sierra. iirc
Nige
chockymonster
| posted on 22/11/06 at 09:35 PM |
Chris.
Hmmm, I don't think we have any at work!
[Edited on 22/11/06 by chockymonster]
smart51
| posted on 22/11/06 at 10:19 PM |
I haven't got one. I rely on the one on the carb. No problems so far.
RazMan
| posted on 23/11/06 at 09:08 AM |
Having a spring at the pedal end only returns the pedal, not the cable. With my setup it is better to have a spring at the TB end otherwise the cable
gets slack and the nipple can come adrift from the pivot.
Raz
amalyos
| posted on 23/11/06 at 12:29 PM |
Your right, but the main reason I added the spring to the pedal end (same as Chris), was to increase the feel of the pedal, as the standard carb
spring was too light.
Winston Todge
| posted on 23/11/06 at 12:49 PM |
The same reason I did mine, along with the M8 studding to act as a return stop.
@ Chocky - The angle poise on my desk now has some well positioned elastic bands!
Chris.
| posted on 23/11/06 at 01:24 PM |
Good source of springs
Old car seats at the scrapyard have loads of springs in, I use them on no end of projects.
TimC
| posted on 23/11/06 at 02:37 PM |
Fit a spring!
I've actually seen a couple of BEC accidents which were due to the throttle being waaaaaay too light. You should have to push hard....
Colin - surprised you haven't done this? Did you do ballet as a boy and as a result have above average pedal feel?
chockymonster
| posted on 23/11/06 at 03:01 PM |
But that involves getting dirty.
Where can I buy a new one
TimC
| posted on 23/11/06 at 03:08 PM |
I'm sure they sell springs in the back of vehicle wiring products catalogue although I think it's a big kit.
I'd go halves with you though and we could chuck what we didn't want on E-bay?
chockymonster
| posted on 23/11/06 at 03:42 PM |
R1 side stand has a perfect spring on it
I now have a much better pedal feel.
G.Man
| posted on 23/11/06 at 04:15 PM |
And the day the throttle pedal does get sticky it will be too late to fix it
Opinions are like backsides..
