chockymonster
posted on 26/11/06 at 08:49 PM |
RT+ Front ride height.
I have a feeling that my front ride height is too low.
The lower 'bones are parallel with the floor but the lower edge of the nose is really low.
What sort of clearance should I have?
![](/galpreviews/a461972-front.jpg) ![Rescued attachment front.jpg](/gallery/a461972-front.jpg) Rescued attachment front.jpg
scoey m
posted on 26/11/06 at 08:57 PM |
Hi paul
Mines only rt but i have about 105mm from lower edge of nose to floor if thats any help to you
amalyos
posted on 26/11/06 at 09:06 PM |
Looks about right, I haven't measured mine, but here's a picture. It looks about the same.
I have caught the bottom of mine a few times but not too many problems.
![](/galpreviews/a461985-front clr.JPG) ![Rescued attachment front clr.JPG](/gallery/a461985-front clr.JPG) Rescued attachment front clr.JPG
Howlor
posted on 26/11/06 at 09:13 PM |
What size boots do you have?!
chockymonster
posted on 26/11/06 at 10:03 PM |
185/60/13's at the front.
Agriv8
posted on 26/11/06 at 10:46 PM |
as you say a guide
( and I thin i am right - even after the sunday trip to the pub ) as a rule of thumb your front lower wisbones need to be parrelel to the floor so yup
chocket jack her up and a few turns on the shocker platforms.
im sure Marc will correct me if i am wrong
from the photo looks like they are still need a little more.
to get it spot on will need a visit to some flat patches and corner weights.'
regards
agriv8
[Edited on 26/11/06 by Agriv8]
amalyos
posted on 27/11/06 at 01:33 PM |
I'm running 195/55/15" so you will sit lower than me by just under an inch approx. (if me maths is right) !!
It does look like you could come up a touch from your photo.
chockymonster
posted on 27/11/06 at 02:19 PM |
I'll have a measure with the car on flat ground, the area outside the garage slopes towards the door, so the rear of the car was higher than
usual.
