Author: Subject: Meshing old style MNR nosecone
chockymonster
posted on 28/11/06 at 12:24 PM Reply With Quote
I've left the piece of paper at home with the dimensions of the mesh I need, can anyone help so I can order it this afternoon?
Also, any advice on how to secure the mesh?
smart51
posted on 28/11/06 at 12:27 PM Reply With Quote
Don't know the size, but I bent over the individual wires around the lip in the nose of the cone, so that the wire looked like a tray. I then used PU adhesive to glue the wire to the inner face of the lip. It looks good from the outside but really messy indide.
chockymonster
posted on 28/11/06 at 12:28 PM Reply With Quote
I'm not worried about the inside, lots of bits are messy on the inside
RazMan
posted on 28/11/06 at 12:29 PM Reply With Quote
If you get some U section rubber around the mesh and use PU adhesive to bond the rubber to the inside of the nose cone. No sharp edges and removeable (with care)
Raz
Agriv8
posted on 28/11/06 at 12:34 PM Reply With Quote
Going To MNR's This Aft will try and remeber to get the tape measure out and Have a measure up for you .
Regards
Agriv8
chockymonster
posted on 28/11/06 at 12:42 PM Reply With Quote
Ta,
that means the only thing left on the list is rear reflectors!
Agriv8
posted on 28/11/06 at 01:01 PM Reply With Quote
get the glue backed ones and attach at sva to you tester requirements one of them area's where each tester has there own ' interparatation ' of the rules
regards
agriv8
chockymonster
posted on 28/11/06 at 01:29 PM Reply With Quote
Any particular place I should pick them up from?
Local motorfactors?
chockymonster
posted on 28/11/06 at 01:59 PM Reply With Quote
600 x 300 is what I need
Agriv8
posted on 28/11/06 at 08:20 PM Reply With Quote
chris mentiones that you had called so didnt bother posting.
passoot has now got new rear shocks and it improved loads but its shows that i need new front oh well 198,000 miles on the clock.
I think flebay sell em if not tisofi
regards
agriv8
chockymonster
posted on 28/11/06 at 08:31 PM Reply With Quote
Yeah,
I had to phone him to ask about nuts for my clutch cable so I figured I'd ask at the same time.
He also had some stick on reflectors so he's sending those down as well!
Mesh is all ordered, £8 for a piece big enough to do the grill
Agriv8
posted on 28/11/06 at 10:03 PM Reply With Quote
ahh that would be the package that chris was dashing to catch the post cart with.
regrads
agriv8
chockymonster
posted on 28/11/06 at 10:05 PM Reply With Quote
regrads
agriv8
Fingers crossed that he made it, will have nothing to do tomorrow otherwise
