Author: Subject: Front suspension...
posted on 5/3/07 at 10:44 PM Reply With Quote
Front suspension...
Zooming on with the build, can hardly keep up with meself.
Its off the 3 foot high stands now on its own wheels! Well two anyway.
Question is I'm a little confused over the nuts and bolts provided in the kit. I've used unf stuff all round the back and on the bushes inboard at the front. Right out of unf gear now but loads of M12.
Its the shock location I'm wondering over, I have none of those little rose joint spacers left and only M12 bolts for the shocks. Are they ok on the shock as they are a little loose being 0.7mm under the unf size of the holes in the spherical of the shock locations, and are washers ok up against them?
What have all you veteren builders used, mine is a Vortx RT.
Chippy
posted on 5/3/07 at 10:52 PM Reply With Quote
I think the correct bolts for the shock's are 1/2", at least they were on mine, easy to get hold of. I used washers to space mine, seems to be working fine. HTH Ray
roadboy
posted on 6/3/07 at 09:27 AM Reply With Quote
Anything with rosejoints is 1/2 " UNF, the bolts for the bushes are 12mm. Cut some 1/2" id tube to make spacers, much neater & also lighter than using washers.
Ian
Jude Performance Services
Krismc
posted on 6/3/07 at 05:56 PM Reply With Quote
plus when you send your car to JPS for the suspension to be set up properly they dont have to faff about with washers!!!!
millemg
posted on 6/3/07 at 06:13 PM Reply With Quote
Mine were all incorrectly M12 too, Chris sent me the correct 1/2 inch UNF's. The spacers supplied are for the rear end, not the front. The bag of 60 M12 washers are to use as front end spacers. I'm making stainless spacers.
[Edited on 6/3/07 by millemg]
posted on 8/3/07 at 08:35 PM Reply With Quote
I didn't get the bag of 60 washers you speak about. There was a lot but not that many.
I've ordered some bolts at different lengths to better suit the brackets and stop the threads touching the body work.
marc n
posted on 8/3/07 at 09:35 PM Reply With Quote
appologies on the bolt front they have been put in the incorrect trays 1/2 to m12 and vice versa same with m10 and 7/16
please email rather than u2u
chrismnrltd@btinternet.com
TimC
posted on 9/3/07 at 08:06 AM Reply With Quote
Erm- I'd better check mine then....
