Author: Subject: Which kit for Granada ?
mstepien
posted on 19/4/07 at 08:37 AM Reply With Quote
A guy at local Ford dealer has a rusty Granada and asked me if there's any kit available for this car. Or maybe any Sierra will do with only minor adaptations ?
Thx,
Michal
Mr Whippy
posted on 19/4/07 at 08:57 AM Reply With Quote
my mk indi is mostly based on the parts used on granada's. I think the drive shafts, column were sierra but the other bits are granada.
Aboardman
posted on 19/4/07 at 09:55 AM Reply With Quote
cobra
mcerd1
posted on 19/4/07 at 11:11 AM Reply With Quote
Most of the parts you'll need for any kit are the same as the sierra ones
but the front hubs and steering cloumns are different from sierra's
and the driveshafts maybe slightly longer (this isn't a problem for some sierra based kits)
Mr Whippy
posted on 19/4/07 at 11:25 AM Reply With Quote
based kits)
just use the hubs front & rear, I have - their 5 stud and have bigger calipers on the front.
DavidM
posted on 19/4/07 at 11:52 AM Reply With Quote
Tornado Raptor V8 is Granada based.
DavidM
posted on 19/4/07 at 11:58 AM Reply With Quote
Piccie: Rescued attachment raptor.jpg
mcerd1
posted on 19/4/07 at 12:31 PM Reply With Quote
....and have bigger calipers on the front.
there the same calipers as ABS, V6 and 4x4 sierra's
[Edited on 19/4/07 by mcerd1]
Mr Whippy
posted on 19/4/07 at 12:50 PM Reply With Quote
think so, huge bloody things that look like they will rip your wheels off if you brake hard
jollygreengiant
posted on 19/4/07 at 01:23 PM Reply With Quote
Luego Viento takes all but the front hubs which are sierra.
mcerd1
posted on 19/4/07 at 04:20 PM Reply With Quote
well they fill a ford 14" alloy anyway
but they'll look a bit smaller in my 16's
but getting back to the original question:
there are lots of kits that will fit Granada bits (I think there is list of kits by donor on totalkitcar.com)
and if you don't like them you can use the Granada parts with a sierra based kit (as they are mostly the same as the higher spec sierra's)
the main sticking points will be the steering column and rack (if applicable) and the front hubs - and for these you can adapt or get some sierra ones
-Robert
Nick Rogers
posted on 19/4/07 at 04:21 PM Reply With Quote
cobras are often based on granadas.
