TimC
| posted on 2/7/07 at 08:03 AM |
Drillling correctly aligned holes for steering column.
Hi
I wonder if anyone has tips for getting the alignment of two holes (One in dash, one in scuttle when fitting the steering column? The flowing curves
of the MNR piece make it more difficult than most I reckon.
I'm keen to just use a hole saw rather than cut slots - which would be a lot less trouble.
I guess I should wait to get the tub on so I can see exactly where the scuttle panel would fit?
It's a bit frustrating as I cant fit my digi dash until I can see what my line of sight is through the wheel.
TC
smart51
| posted on 2/7/07 at 09:12 AM |
Cut a slot in the back of the scuttle. That way, if you need to remove the scuttle, and you will eventually, you don't have to remove the
steering column first.
I did mine by sitting the scuttle on the column and marking it, then remove more and more with a dremmel sanding tool till ithad enough clearance.
Howlor
| posted on 2/7/07 at 09:28 AM |
You can however get away with a slot at the bonnet end and a hole at the cockpit end. My hole was about 25mm from the lower edge of the dash and
central to the seating position.
You can then remove the steering wheel and slide off the scuttle over the column.
TimC
| posted on 2/7/07 at 09:46 AM |
I do take your points. However, if I were to need to take the scuttle off, then the job would be so majorly huge (i.e. the problem beneath the
scuttle is a monster anyway) that removing the steering column would be the least of my worries.
Therefore, in the interest of neatness, I'd like to do it with two holes. Anyone done this?
Howlor
| posted on 2/7/07 at 10:01 AM |
My scuttle came off in 5 mins flat. 4 dome head bolts holding it down on the inner flanges, then 3 multi plugs to connect dash and switches etc.
I just covered my slot with a carbon cover.
amalyos
| posted on 2/7/07 at 10:06 AM |
I started with a hole, but quickly ended up with a slot, as it was a pain in the a*se taking the scuttle on and off.
My scuttle comes off with just 4 screws as well.
http://stevembuild.blogspot.com
worX
| posted on 2/7/07 at 10:16 AM |
I'd be cutting a slot int he scuttle side of it too I'm afraid Matt!
Dillinger1977
| posted on 2/7/07 at 11:31 AM |
yer all wimps
it was a long time ago ( ) but this is what I did..
http://rogb.locostsites.co.uk/05august.htm
lots and lots of measuring and angles.
-Rog
worX
| posted on 2/7/07 at 03:28 PM |
If yours is the same height as Rog's then I would definitely drill it, mine was a lot lower so there was no point...
road warrior
| posted on 3/7/07 at 01:01 PM |
Hi Tim
Do this as per the post by Dillinger1977. But fit the tub first so you know exactly where the scuttle will sit. Take your time, you only get one go at
this type of stuff.
Sonja
TimC
| posted on 3/7/07 at 02:01 PM |
Cheers Rog & Sonja.
Steve (Worx) - who the hell is Matt?
worX
| posted on 5/7/07 at 06:08 AM |
Sorry Tim,
I must be losing the plot somewhere!!!
cheers,
Jeremiah
chockymonster
| posted on 5/7/07 at 08:10 AM |
Tim,
are you using the sierra column shroud?
When I did the one under the bonnet I then made a CF blanking plate to make the hole look tidier, that's mainly because every bloody hole I cut
always went wrong even though it was measured twice and cut once (and then fettled to make it actually fit)
