Author: Subject: Inboard suspension fitting
vinny1275
posted on 2/7/07 at 08:12 AM Reply With Quote
Morning all,
Tried trial-fitting the front suspension at the weekend (I wanted to test it out before I get anywhere near bodywork)... I fitted the pivot for the shock / pushrod, but the spacers I have are too big to fit the eye into the pivot mounting. For the other RT builders on here, did you have more than one size spacer? Mine are all about the same size (about 7.5mm long), but it looks like they should be more like 6.
I would call Marc, but he's off on his honeymoon for a fortnight......
Anyone any ideas?
Thanks,
Vince
amalyos
posted on 2/7/07 at 10:01 AM Reply With Quote
I did file some of my spacers down. There was only 1 size.
http://stevembuild.blogspot.com
zxrlocost
posted on 2/7/07 at 10:18 AM Reply With Quote
hi vince there is a pic on your site where a brake pipe goes up in there air round down then into a P clip
I dont know if this is finished or not but I would shorten it
thanks chris
Agriv8
posted on 2/7/07 at 12:39 PM Reply With Quote
vinney,
Back from arran post up a photo ( as I can visiualise which bit you are on about )if you can.I hope I would be able to advise in marcs absence.
Regards
Agriv8
