greglogan
posted on 25/7/07 at 09:21 PM |
Transferring Drive from Engine to Diff
Hi guys
what is the best way to transfer drive from the bike engine (Fireblade probably) to the diff at the back? I guess there would be problems with a chain
that length?? So is there some kind of adaptor or whats the best way to do it?
Greg.
Women are meant to be loved, not understood.
alister667
posted on 25/7/07 at 09:24 PM |
Assuming it's a front engined rear wheel drive layout, most folks use a propshaft bolted to an adaptor that replaces the sprocket on the bike
engine.
Good Luck
Ali
Fatgadget
posted on 25/7/07 at 09:33 PM |
Best way is to bolt a motor directly on each wheel like they do on diesel electric locomotives!
bigrich
posted on 25/7/07 at 09:38 PM |
fit the engine at 90 degrees from normal
replace sprocket with redily available adaptor
fit a sliding joint to a propshaft or custom made prop and bolt to the diff
greglogan
posted on 25/7/07 at 09:42 PM |
Hadn't actually thought of turning the engine 90 deg. Makes sense! Guess that does away with the need for a chain drive diff. Thanks!
Greg.
nitram38
posted on 26/7/07 at 01:05 PM |
Or you can put the engine in the rear and have an electric reverse:
Reverse setup
tigris
posted on 26/7/07 at 02:49 PM |
any more info or links on that reverse? Thanks
nitram38
posted on 26/7/07 at 04:25 PM |
I bought it from lynx racing. Not cheap, but it is good!
Try www.lynxae.co.uk and speak to Jon
blue2cv
posted on 26/7/07 at 07:24 PM |
Or you can use a transaxle
nitram38
posted on 26/7/07 at 08:03 PM |
My reservation with a transaxle (apart from cost) is weight.
I went the diff route too as it was a cheap lsd option.
But saying all that, the transaxle is a solidly engineered option and it looks bloody nice too.
[Edited on 26/7/2007 by nitram38]
