smart51
posted on 2/8/07 at 11:45 AM |
Sprocket adaptor ID
What is the inner diameter of an MNR sprocket adaptor for an R1 (what OD do I have to get a socket turned down to?)
Also what size socket do I need for the nut on the R1 output shaft?
Coose
posted on 2/8/07 at 11:51 AM |
I don't know about your first question without dropping my prop off, but the answer to the second is 36mm.
Spin 'er off Well...
smart51
posted on 2/8/07 at 06:22 PM |
36mm socket with a 50mm or less OD (the sprocket adapter is 2" ID). I guy at work with a lathe will turn a couple of mm of my new socket for
me.
chockymonster
posted on 2/8/07 at 07:25 PM |
me.
I used a 36mm impact socket from halfords. No turning down needed.
smart51
posted on 2/8/07 at 09:36 PM |
the one I've got is 51mm OD, 0.5mm too big. Typical.
millemg
posted on 4/8/07 at 09:23 AM |
I have loose fitted the sprocket adaptor and wondered if I need the Yamaha tab washer behind the nut. It looks like it will be awkward to get the
socket on. ??
smart51
posted on 5/8/07 at 01:55 PM |
I have the tab washer but the sprocket adapter takes up all the spines. I thought about having 1mm skimmed of the adapter so the washer would have
something to bite to but then decided to use threadlock instead.
