Author: Subject: MNR body tub fitting help + more :)
millemg
posted on 4/8/07 at 09:15 AM Reply With Quote
1. - Can anybody give me any hints on body tub fitting, particularly at the rear. I need to cut the inner edge of the tub where it meets the outer side of the roll bar. I trial fitted it, but the width of the roll bar stops it going all the way forward into position. Is there a measurement for this cut out ? Or any tips ?
2. - Plumbing. I have looked at a few build pics and want to know what hoses I need etc for the R1 engine. I have a Polo rad which I still need to mount. Also it looks like the R1 thermostat housing needs to be mounted elsewhere, again, any tips would be helpful.
My build is going quite slowly as I am in the middle of house moving and building project. !!! It's getting there .!!
More questions WILL follow !!
Thanks in advance
She's lurking in there somewhere..!!!
[Edited on 4/8/07 by millemg]
nib1980
posted on 4/8/07 at 09:25 AM Reply With Quote
I used lots of cardboard templates to give me the rough ideas/sizes , then cut less than i actually think and finish it off with a file.
hope that helps
graememk
posted on 4/8/07 at 11:26 AM Reply With Quote
i went in all cack handed cut out to much and thats why my car looks like its been put together by a blind 5 year old
so yes cardboard pen and a knife.... then a file.
posted on 5/8/07 at 11:32 AM Reply With Quote
Made a right horlicks of mine having to put it on by myself!
With it being my first go with my new dremmel I also removed far too much fibrglass round the roll bar. DOH!
chockymonster
posted on 5/8/07 at 07:39 PM Reply With Quote
Cardboard template is much better than the visualisation/get it wrong method.
There's a plumbing bit on my website that works wonders in my car, it includes the extra hoses I used to move the 'stat from it's hard mount position.
I cut the hard mount pipe in 2 so that you there was enough meat left on both ends to secure a piece of hose onto, I used 19mm samco superflex and it seems to have worked. From memory the pictures you want are around about July in the build section.
JoaoCaldeira
posted on 5/8/07 at 09:02 PM Reply With Quote
About the stat, In order to keep it simple I just left mine in place and cut a round bif off the bonnet / fibreglass and filled it with a ... how do you call the thing to get the tea through? The thing with a metal mesh...
Welll take a look here
Painted black, and glued by the inside looks perfect
Joao
posted on 6/8/07 at 11:13 AM Reply With Quote
Tea strainer.....
TimC
posted on 6/8/07 at 11:16 AM Reply With Quote
Are you sure that the 'stat won't fit with the new bodywork? I've had a look and I reckon it might just go../.
chockymonster
posted on 6/8/07 at 11:32 AM Reply With Quote
The 5PW didn't, it actually stuck out over the chassis rail. It's hard mounted to the outlet on the engine
millemg
posted on 6/8/07 at 03:56 PM Reply With Quote
Yeah, mine is a 5PW and it looks like it's way too far out to go under.
Not sure about a "tea strainer" though
[Edited on 6/8/07 by millemg]
chockymonster
posted on 6/8/07 at 06:46 PM Reply With Quote
It won't fit under without mods to the bonnet which I didn't want to do either so I moved it.
