finlay
| posted on 27/1/08 at 12:41 PM |
pressing bearings into hubs
hello there
just picked up my kit from MNR and was going through all the parts and noticed that none of the bearings were pressed into the front and rear hubs
unfortunately i dont have access to a hydraulic press, whats the best way to go about fitting the bearings ?
cheers
Finlay
Thinking about it
| posted on 27/1/08 at 12:44 PM |
Can you not use the vice? Usually works using tube etc or old bearings to push the new ones in.
blakep82
| posted on 27/1/08 at 12:47 PM |
mmm, i had this the other week... i tried a vice, but unless you've got a really big vice and a really big socket its not easy.
any engineering firms or any garages around you?
i went a local independant van hire place and asked, the guy said, "bearing press is round there, use a big socket to fit the bearing and go for
it" left me to do it myself
[Edited on 27/1/08 by blakep82]
________________________
| posted on 27/1/08 at 12:58 PM |
Sierra bearings aren't that tight, they will tap in with a hammer without any problems.
Agriv8
| posted on 27/1/08 at 01:17 PM |
Finlay,
Sierra rears I just warmed thr hub carrier up in the oven ( Wife was out ! ) and chilled the racces and then tapped them in with a socket (you need to
drify them in Square )
Fronts are you using MNR alloy hubs ?
Regards
Agriv8
bassett
| posted on 27/1/08 at 03:29 PM |
sorry to hi jack the thread but on the my rears i've got push in shafts and the races are already in the hubs and we have tapered bearings,
would we still need to press these in?
finlay
| posted on 27/1/08 at 03:59 PM |
quote: Originally posted by Agriv8
Finlay,
Regards
Agriv8
hi
thanks for the info
i have a raceleda front end
cheers
Davey D
| posted on 27/1/08 at 05:26 PM |
on the front & rear it uses taper bearing, which dont need pressing in. there is just the retaining cover with the rubber seal that needs pressing
in, but its so thin, and light that a vice can do the job easily
[Edited on 27/1/08 by Davey D]
Johneturbo
| posted on 27/1/08 at 06:47 PM |
But you still need to fit the outer race that sits in the hub. i used Agri8 suggestion, if your lucky the outer race will just drop in, if not use a
socket and hammer
Basset are you fitting new bearings? if so you will get the outer race in the kit, best to change that too
[Edited on 27/1/08 by Johneturbo]
stuart_g
| posted on 27/1/08 at 08:55 PM |
Bearing seats were already fitted to my Raceleda front hubs. The bearings should be able to be put on and taken off the stub axle by hand, if not
there is something wrong.
Bearing seats can be tapped in using a large socket around the edge of the seat.
[Edited on 27/1/08 by stuart_g]
Agriv8
| posted on 27/1/08 at 10:02 PM |
In that case - I would fire an email of to MNR as I belive marc usually fits the races to the raceleda hubs ,
You can fit them ( buy the hubs you need to get really quite hot and the races VERY cold and you really do only have one chance to get it right and
the hubs are not cheep !!
Though it may be that Marc has changed to toleraences on the hubs and they are now a home fit job but if it was me I would check first.
Regards
Agriv8
marc n
| posted on 28/1/08 at 08:48 AM |
hi all
warm hubs in oven 15mins
races in freezer,
and they will push in by hand easily, not keen on the press method as its easy to damage the races and the hubs if not in square
cheers
marc
please email rather than u2u
chrismnrltd@btinternet.com
finlay
| posted on 12/2/08 at 11:46 AM |
worked a treat
