Author: Subject: mnr rear upright, is this correct ?
finlay
posted on 5/3/08 at 02:15 PM Reply With Quote
hi all
before i go and fit the other side, is this rear upright on the correct side ?
cheers
worX
posted on 5/3/08 at 02:16 PM Reply With Quote
Yeppington!
Agriv8
posted on 5/3/08 at 02:27 PM Reply With Quote
Looks good to me.
PS what colour have you gone for
regards
Agriv8
finlay
posted on 5/3/08 at 02:28 PM Reply With Quote
cheers
all black, same as yours i m afraid, but with red engine bay, all hoses etc
Originally posted by Agriv8
Looks good to me.
regards
Agriv8
stuart_g
posted on 5/3/08 at 02:31 PM Reply With Quote
Here is a pic of mine. You can put the shock in front or behind the wishbone. I put mine behind as it was more upright that way. Rescued attachment Drivers side rear brakes.JPG
GeorgeM
posted on 5/3/08 at 08:40 PM Reply With Quote
think you'll find that with the new style
upright the calliper is designed to mount
at the front. This would mean you have
the upright on the wrong side - sorry
Check with marc
GeorgeM
Davey D
posted on 5/3/08 at 11:06 PM Reply With Quote
ive fitted mine to the front, but when i went to MNR the other weekend mark had put some on the back... when i questioned him about it he said it is just down to personal preference
Johneturbo
posted on 5/3/08 at 11:08 PM Reply With Quote
i also thought with the new uprights the calipers mount on the front side!?
i'd prefure them the other way to meet up with the copper lines.
did you just swap the uprights around stu?
Johneturbo
posted on 5/3/08 at 11:11 PM Reply With Quote
you answered my question before i asked it!
i'm gona swap mine around,as i dont like having the braided line running between the wishbone and driveshaft.
[Edited on 5/3/08 by Johneturbo]
neilj37
posted on 6/3/08 at 12:46 PM Reply With Quote
Some good photos here of how Davey D has fitted them:
http://www.dpdnet.co.uk/kitcarbuild_dec.html
[Edited on 6/3/08 by neilj37]
stuart_g
posted on 6/3/08 at 04:38 PM Reply With Quote
I did originally fit mine with the caliper at the front but again after going to see Marc and Chris the other week I decided to fit them the conventional way to suit where I had also run my brake pipes. The standard flexi's supplied would not reach with the caliper on the front and copper lines at the rear of the arch.
My adjuster on the shock also hits the wishbone if fitted with it on the inside. I will see if there is clearance when it is on it's wheels, then turn it around.
[Edited on 6/3/08 by stuart_g]
finlay
posted on 7/3/08 at 10:44 AM Reply With Quote
fitted my calipers to the rear
cheers
