Author: Subject: Headlamp mounting bar position
stuart_g
posted on 5/3/08 at 04:43 PM Reply With Quote
Where is the correct place for this to be fitted? Is it as far forward as possible?
I have seen a few cars with it in different positions.
Stuart.
posted on 5/3/08 at 04:46 PM Reply With Quote
On my Indy I fitted it directly in line with the upper shock mounts on the chassis. Not sayin it's reight or wrong, just where I thought it looked about right. No issues at SVA.
Johneturbo
posted on 5/3/08 at 06:47 PM Reply With Quote
Hey Stu,
sounds like your making great progress
i mounted mine inline with the front top wishbone mounting point Rescued attachment lightBar.jpg
stuart_g
posted on 6/3/08 at 10:18 AM Reply With Quote
Progress is slow at the moment seems like I'm spending a lot of time on the car but hardly anything getting done. I guess it goes like this sometimes.
I had planned to put the headlamp bar in this position also but I had seen pictures of it fitted further back above the suspension pushrod. I'll put it above the front wishbone mount I think.
Davey D
posted on 6/3/08 at 10:38 AM Reply With Quote
i havent fitted mine yet... ( just waiting for more rivnuts to arrive)
but when i do fit it im going to be fitting it above the front leg of the top wishbone. in between the 2 plates welded to the tube
road warrior
posted on 6/3/08 at 11:21 AM Reply With Quote
When mounting the headlamp bracket keep the suspension movement in mind. e.g. make sure the suspension arms can't hit the base of the headlamp or wiring.
Davey D
posted on 6/3/08 at 08:32 PM Reply With Quote
to test the suspesion on the front end of mine.. bfore i got the radiator on i stood on the frame, and jumped up and down, and it hardly moved
marc n
posted on 7/3/08 at 07:22 AM Reply With Quote
hi stuart
i normally fix the headlamp bar so it ends up in the middle of the top wishbone, but have seen people fit them right at the front or as far back as the bonnet area
cheers
marc
please email rather than u2u
chrismnrltd@btinternet.com
