bassett
| posted on 19/3/08 at 06:55 PM |
Springs and dampers
Hi, with the RT inboard are the front springs and dampers (12inch) the fronts and the longer at the rear?
Adam
stuart_g
| posted on 19/3/08 at 07:00 PM |
Yes
bassett
| posted on 19/3/08 at 07:16 PM |
Thanks again Stuart. Also a query with the pivoting arms, if your looking at one side only is it cylindrical radial bearing then radial thrust bearing
then thrust washer then another radial thrust bearing as i havent got the manual?
Adam
stuart_g
| posted on 19/3/08 at 07:41 PM |
Yes it is according to the manual although I can't remember fitting that many bearings or even having that many bearings in the kit
I'm off to check now..........
Mine are as below...phew.
[Edited on 19/3/08 by stuart_g]
vinny1275
| posted on 19/3/08 at 08:09 PM |
I remember the manual's slightly wrong, this is what I had from Marc when I fitted mine:
instructions are wrong you have the correct amount, should be fitted washer , roller bearing, washer
HTH
Vince
GeorgeM
| posted on 19/3/08 at 08:59 PM |
as above, washer, bearing, washer. Manual
has them other way round.
ssh, MNR got something wrong
bassett
| posted on 19/3/08 at 11:46 PM |
Cheers guys that does sound more logical and just aswell i didnt get time for that job tonight or i could easily have spent a few hours looking
through the rest of the unopened boxes for the extra washers.
Adam
