stuart_g
posted on 31/3/08 at 03:28 PM |
exhaust mounting
What is used to fix the exhaust to the car at the outlet end.
I have MNR satinless exhaust and made a bracket to bolt to the underside of the car. What is used to attach the exhaust to this bracket? The tail pipe
slides into the silencer, do I just use a 'U' clamp or is there some vibration bobbins fitted?
A pic would be very helpful.
marc n
posted on 31/3/08 at 03:57 PM |
u clamp round the tailpipe, use the two studs of the u clamp to attach a l shaped bracket with a lower mount onto you chassis bracket adding a bobbin
between the two
cheers
marc
please email rather than u2u
chrismnrltd@btinternet.com
stuart_g
posted on 31/3/08 at 04:04 PM |
Thanks Marc.
Johneturbo
posted on 1/4/08 at 06:28 PM |
Hey Stu,
This is how i've mounted mine.
