Davey D
posted on 15/5/08 at 01:19 PM |
MNR supplied Wiring loom
Im getting the lighting sorted, as ive got all the wiring loom from the Bike done.
Im using the Bike ignition switch to power everythng on/off, so the plan is to use a relay in the Bike ignition wiring to switch the lighting loom
on.
My question is: What do each of the wires switch?
i think there are 2x white/red, 1x white, and 1x brown
im assuming that it is designed for a 2x position ignition, brown being -ve , the 2x white powering 1 part, and the 1x white powering another?
marc n
posted on 15/5/08 at 01:21 PM |
can t tell you this second, but our wiring man is coming this evening / tomorrow so will ask him then for you
cheers
marc
please email rather than u2u
chrismnrltd@btinternet.com
Davey D
posted on 15/5/08 at 01:26 PM |
Thanks for that Marc
While i remember to ask - did you manage to get some shorter steering rack extensions made up, as its a bit of a bugger pushing the car around with so
much toe out hehe
marc n
posted on 15/5/08 at 01:27 PM |
yep we have now got them back from the anodiser, can you send an email to chris as a reminder and we can send them off tomorrow morning so you will
get them for the weekend
cheers
marc
bassett
posted on 15/5/08 at 01:58 PM |
I also need to know the same for later in the build, would you mind letting me know what you find out.
Adam
Davey D
posted on 19/5/08 at 08:39 AM |
Marc - did you manage to find out the details of this?
marc n
posted on 19/5/08 at 10:12 AM |
he is here this afternoon again, i will ask him, i must admit i forgot last time he was here, have just written large note on desk
cheers
marc
Davey D
posted on 19/5/08 at 10:31 AM |
Bah! what are you like
im just the same though... ill note in my mind something that i must get done on a particular day... 2 mins later, and ive forgotten all about it...
Im only 28.. what will i be like in another 30 years
Agriv8
posted on 19/5/08 at 11:04 AM |
If I remember I will have a dig about under my dash as those are the sma coulors as mine
Regards
Agriv8
Ps Marc you about tomorow or thur Eve ?
marc n
posted on 19/5/08 at 01:47 PM |
pretty much every night this week i will be here late
cheers
marc
Agriv8
posted on 20/5/08 at 05:45 PM |
'ere you go
Brown = Power
White = Ign
White and red = Start
if you need anything further let me know
Regards
Agriv8
Mark might be over tomorow Eve
[Edited on 20/5/08 by Agriv8]
bassett
posted on 20/5/08 at 06:44 PM |
with a lucas ignition barell(4 in line pins) what should go to what?
cheers
Adam
Agriv8
posted on 20/5/08 at 08:06 PM |
any chance of a photo or where it came from ( part number ect ) and I should be able to point you in the right direction.
Not seen 4 pins in line ( seen 3 of 4 pins arround the edge )
Regards
Agriv8
bassett
posted on 20/5/08 at 08:51 PM |
Its one MNR supplied, lucas switch 30608 has 4 pins at the back but split into two ie two connected to one another and has 2 positions. Also the end
of that white and red wire thats going to the starter right?
Agriv8
posted on 21/5/08 at 07:14 AM |
Ahh I see
So two 'pined pairs'
So you need to put brown ( battery feed ) to '1 of pairs' and white to the 'other' ( switched ignition ) this will give you
ignition on So lights, indicators ect should work.
The switch looks someting like this
[img]http://www.tms-motorcycles.co.uk/store/products/images/large/271-1.jpg?0.280115[/img]
Just to add suspect you must be using a start button. To connect that you will need to make a cable to go from the pin thats paired with the one you
have the white on.
The other side of your start switch then needs to go to the white red this is the feed to spin the starter motor up.
Ill mod that picture and it will make more sense I hope.
Ps No waranties that I have it right buy the way.
regards
Agriv8
Agriv8
posted on 21/5/08 at 07:39 AM |
Somthing like this
Regards
Agriv8
Davey D
posted on 21/5/08 at 11:28 AM |
Excellent - thanks for that
I notice there is a white/red wire that goes into the engine bay for the starter, so i presume that that wire just goes back to the one in the
ingnition... maybe via a relay? so i should be able to chop that bit out of the loom then.
More weight saving
bassett
posted on 21/5/08 at 01:28 PM |
Sorry to keep hijacking the thread DaveyD. Should i wire the brown and white as above(to ign barrel) the red/white to a start swich then to the
ignition barrel and the other end to the starter. My 5pw has a +lead with relay and then goes to the battery but where should the red/white
connect?
Adam
Agriv8
posted on 21/5/08 at 02:31 PM |
More weight saving
In most car engine the relay is the 'starter selaniod' ( the little lump an the side of the main starter motor ) so on the bike one you
need to connect the White and red to the relay that has the fat cable that runs to the starter motor motor.
Hope that make sense if not I'll try and cobble another picture together.
regards
AGRiv8
Agriv8
posted on 21/5/08 at 02:32 PM |
Basset,
Ill try and have a llok at the 5pw wiring scematic tonight and get back to you.
regards
Agriv8
Davey D
posted on 21/5/08 at 03:43 PM |
More weight saving
regards
AGRiv8
The bike engine already starts and runs on its own original loom. im only using the MNR loom for the lighting, so the wiring to the starter in the MNR
loom is redundant
bassett
posted on 22/5/08 at 10:29 AM |
Agriv8 that would be a great help cheers.
Adam
marc n
posted on 22/5/08 at 07:35 PM |
cheers iain
ive been so busy i forgot to ask the sparky
ive been late everynight working or delivering cars, im absoloutely knakered and im up at 5-30 for an sva
cheers
marc
