posted on 9/6/08 at 10:07 AM |
Exhaust SVA Question
Will my current exhaust setup be OK at Beverly SVA? (15th July)
Standard MNR can and manifold.
Will my rear hanger be OK or should I cover it with summit?
Sorry to ask this again, just wondering what other MNR's have got away with?
Thanks,
indykid
| posted on 9/6/08 at 10:15 AM |
both ends of your can and the rear bracket look to have unacceptable radii. how about making a long heatshield to cover it all?
tom
worX
| posted on 9/6/08 at 10:16 AM |
With regard to the rear hanger - they are classed as "below the underside of the car" line and as such can be a bit sticky-outy! and will
still be a pass
Should be fine mate...
Humbug
| posted on 9/6/08 at 10:26 AM |
still be a pass
...though I would turn the U clamp so the bolt ends and nuts face underneath
StevieB
| posted on 9/6/08 at 10:54 AM |
Safe is better than sorry - I'll be making a big heat shield (like the Caterham items) and putting plenty of edge trim on there.
It doesn't take much effort, can be taken off later and is far better than failing SVA for something daft and simple!
richardh
| posted on 12/6/08 at 07:54 PM |
mine needed a shield over the edges as they are not radiused enougfh and sharp
the mount on mine is the same and was not an issue first time round as the nuts are unreachable with the testers metal knee ball due to the exit bend
of the pipe.
bitsilly
| posted on 12/6/08 at 08:00 PM |
I am building a cobra and have long since decided to treat the SVA as a two part test. Do what you can but be prepared to fail and then sort out what
you must with some advice from the inspector on each point.
I may be wrong!
bitsilly
I may be wrong!
Krismc
| posted on 13/6/08 at 05:13 PM |
Looks similar to mine, but ive got a clio silencer on for sva, Only problem with mine was that even with a cat, and LC1 lamda the emissions where very
high.
...still waiting for my retest!!!
