Author: Subject: Body Tub Hole Cut Outs
GraemeC
posted on 25/8/08 at 11:10 AM Reply With Quote
I'm going to take the plunge and cut the holes in the body tub this afternoon.
Cardboard templates done, but what diameter holes have others used?
There are two holes pre-drilled in the front of the tub, one each side. These align with the upper front wishbone fixing, although offset from centre. I am assuming this marks the required centre position for the hole to compensate for the wishbone angle as it comes through the body. Any body confirm this?
marc n
posted on 25/8/08 at 03:40 PM Reply With Quote
hi graeme
i use a 76mm holesaw ( only because thats the largest i have ) front pilots holes are the ones i use
best regards
marc
please email rather than u2u
chrismnrltd@btinternet.com
marc n
posted on 25/8/08 at 03:41 PM Reply With Quote
the one i use for the pushrods is a 38mm
cheers
marc
GraemeC
posted on 25/8/08 at 04:44 PM Reply With Quote
Thanks Marc.
By the way did you find my other exhaust bits?
Graeme
