Hi chaps fitted a trickshifter that came with my car but was never fitted, ive fitted as per instuctions double checked everything and have an issue
with it..
The problem is this, when the ignition is on but engine off, it tells you to move the gear lever and you should hear a bleep and led illuminate on the
control box when you feel resistance if set right (i do get the bleep and the light so it all seems well) But it then says flick the switch on the
control box while the engine is running, this is the test for the spark interupt and as you do it you should feel a miss beat of the engine simulating
the spark cut, for the flat shift, i again get the green led and bleep at this point but no miss beat of the engine, so it seems its not cutting the
sparks at all to me...
But the wire to the coils is grey and ive definatley connected into the correct one and before it splits into the 4 one for each coil pack, anyone got
any idea's at all. sent email to trickshifter but had no reply as yet, thought i would try on here but long shot i know..
GSXR1000 k1 indy ??
I fitted one on my zx10r, when you flick the momentary switch, are you sure its not cutting the spark, as I thought mine was not working either as I was expecting the engine to almost cut out, but its just the slightest of engine note change only, although if you rev the engine to around 6000rpm it is lot more noticeable.
I have the trickshifter instructions, do you want them ?
Mines not fitted yet, so cannot help.
Mydrian T9 on here used to run one (now mine)
Ive spoken with trickshifter and found them really helpful, flatshifter are meant to be helpful too. I know Flatshifter took over trick...
[Edited on 12/2/11 by T66]
Cheers for the replys guys T66 ive actually got the instructions, and done everything it says properly just it did'nt seem to interupt the spark
when i tested it that was all...
Thant said the engine was on idle and cold so it was sort of hunting up and down a touch on the cold start idle in the garage..
PAUL = so are you saying on idle its hardly detectable its cutting the spark,,, on the test setting what does it actually do cut the sparks for 1/2 a
second or something, can you give me a quick description what the noticable interupt is and how you test yours you say 6000rpm ish etc
Sounds like you have connected it right but as mentioned previously the cut is extremely subtle although very distinguishable - you will know straight
away.
I would let the engine run a while to get it ticking over smoothly and then try, if it still doesnt work then check your connection to the coil power
and if that fails speak with the lads at Tricksifter now Flatshifter - extremely helpful and even answer the phone on a Sunday
I used one on my Blackbird carb motor and worked a treat... :
Doesnt sound like a big problem, good luck
Originally posted by neo2
PAUL = so are you saying on idle its hardly detectable its cutting the spark,,, on the test setting what does it actually do cut the sparks for 1/2 a second or something, can you give me a quick description what the noticable interupt is and how you test yours you say 6000rpm ish etc
cheers guys will do some more tests and if i get no joy will ring trickshifter/flatshifter
Rob
Telephoned trickshifter and they are really helpfull guys down there spot on, anyway, they told me to check and test a few things and it appears the unit is faulty and the dianosis is a blown diode inside, its rebuildable so not mega expensive but at least ive got it narrowed down...
nice one....
