hi dose any of you guys no of anyone thats works at the ecu units on a 929 fireblade to remove the hiss system so you can run without it............... many thanks jonny
I believe the US ecu doesnt use the system
American ecu
does not have hiss security but there are a couple of pin position changes to make if you use it with UK loom. Alternatively motomatrix will match a
key to your ecu for you if you send them the ecu.
Regards
Watch this for an idea of what you need. I don't know any way to fool the ecu if you don't have the key and transponder.
Try Malc at yorkshire engines, he will probably be able to supply the bits required
i no of a fella in england removes the hiss ...but at a premium its about £300+vat what is deff not lowcost ...............
