i read on this forum a little while ago about someone supercharging an r1 motor for a caterham clone. could the same be done for the hayabusa? if so what would be the gains with the same mini type supercharger? ive fell in love with the idea of supercharging after seeing the ariel atom tested on top gear, what a mad car! i'd give my right nut for that car, not my left though.....thats my dominant
TTS do a supercharged kit which bolts on to the end of the engine as a replacement for the clutch cover I think, so no need for drive belts, etc.
£4500 though!
Go to - http://www.tts-performance.com/busasupercharged.php
Is that the one you were thinking of?
Adam.
TTS have a supercharged Hayabusa Westfield in their premises (or they did a couple of weeks ago and it had been there a while). They do a kit using a
rotrex supercharger which is far more efficient than the design used on a mini. It's basically a gear driven turbo so it's tiny and easy to
package into a small car.
I was going to put one on a Busa engine in my Caterham but ended up going for a turbo instead because I couldn't fit the direct drive rotrex
supercharger where it needed to go and I didn't fancy a belt driven one.
I think there's potentially a real benefit at higher power outputs with a supercharger as there is not lag. Now apparently, there is negligible
lag with a small turbo, but once a bigger turbo is used for higher power outputs, lag becomes more of an issue.
My thinking was that with a light Caterham, 300+ bhp with a small turbo & no lag will be ample.
I think the supercharged busa motor has run faster drag bike times than a turbo'd motor in the ultimate street (or something) class this year
although I am not sure how relevant this is.
I have seen the TTS supercharger kit but at that price i would rather have a turbo system. I was trying to find a cheaper alternative to such a
system, one that may not make as much power but still isnt to bad. The TTS kit is amazing, if i had the money for such a thing. but if i had that kind
money, i would just buy a radical or atom and be done with it..4500pounds is about 8000 us dollars right?
[Edited on 11/1/05 by sean951]
I doubt you would get one any cheaper than a holeshot:
http://www.holeshotracing.co.uk/tuning/turbo_bike_hayabusa.asp
Mark
Mark18: That's the bike prices, cars are a bit more:
http://www.holeshotracing.co.uk/tuning/turbo_car_hayabusa.asp
Sean951: There are plenty of people in the US who do turbo Busa motors (for drag racing mainly) so if you're buying with the $, it would make
more sense to buy from the US.
Yes you will get it cheaper if you go directly to MC Express, the company from which Holeshot buys all his stuff and sells it back to you.
I got a quote from them for a turbo kit for my Fireblade engine and it is about 15% cheaper
They are also willing to sell you bits and pieces rather than a complete kit. For a brand new turbo complete with the wastegate and blow off valve
together with the airbox (which are the most critical itmes for a turbo system) they quoted £700. Now you can compare for yourself!!
There is a hell of a lot more work than just bolting a turbo on though. Chasis rails need to be modified,intercooler,exhaust system,engine spacer
gasket etc etc. To get a car converted to a possible 450bhp busa turbo your looking at around 7.5k
yes, building a car with a 450hp busa motor would be expensive.....but what could touch it in the same price range, forget that......what could
compete with it period. But thats not really what i was looking to do, i may just build my own kit, i was just seeing what my options where. i vastly
modified my porsche 944 turbo, so i was trying to go the supercharger route. damn, why do turbos have to be so efficient. looks like i will end up
doing the turbo eventualy. first i have to start on the car though.
Originally posted by phil_far
They are also willing to sell you bits and pieces rather than a complete kit. For a brand new turbo complete with the wastegate and blow off valve together with the airbox (which are the most critical itmes for a turbo system) they quoted £700. Now you can compare for yourself!!
In your bill you should count 3 or 4 spare engines....
Have'nt Holeshot Racing built a 650bhp busa engine!?!?!?! Acording to this dvd i have they like getting big power out these motors!
Yes 650hp in a bike
There is not much Jack at holeshot doesnt know about the busa motor.He also holds the land speed record on a bike at 241 mph.
It is recommended anything over 250bhp the rods and pistons changed.The head will need to be removed and a spacer gasket fitted at the least unless je
forged turbo pistons are used.
I looked into fitting a turbo to mine but thought better of it due to turbo lag etc. A big bore creates power right through the rev range and is a a
lot more reliable. Even a big bore ,yoshi cams,gas flow,recut valves etc is around £3000 .
If you fancy doing a turbo without stronger rods look at the picture.The motor in the picture only had 250bhp.
Originally posted by tony9876
It is recommended anything over 250bhp the rods and pistons changed.The head will need to be removed and a spacer gasket fitted at the least unless je forged turbo pistons are used.
