Thanks for any advice given.
I am going to fit a bike engine to a Tiger cat.
I have decided to go down the carburettor route as this does appear to be a little bit less in the way of cost and setting up.
Could anyone tell me please of the following 3 models what year did they stop manufacturing these bike with carbs and start the fuel injection
models
Fireblade
ZX9R
Yamaha R1
Do I need a new modified sump or can you get away with a baffle plate for the following.
Fireblade
ZX9R
Yamaha R1
Do I need a new clutch or can you get away with up rating the springs for the following.
Fireblade
ZX9R
Yamaha R1
Which one is the strongest when fitted to a BEC?
Any ones in particular to avoid?
Will rejetting of the carbs be required?
Thanks Dave.
Can only help on the R1.
Carbs up to 2001, baffled sump is fine and double up on the spring in the clutch.
Out of the three I'd go R1.
ZX9
1. Unsure of the age thingy
2.You can baffle it if you have enough clearance. I havent so it will be a new sump for mine.
3. Just springs but time will tell with mine.
The zx9 is not the quickest out of all of them but have a look at Wadders drag times. They may suprise you!
[Edited on 28/1/08 by matt.c]
I'm sure it will be fine, but I was under the impression that the Cat was a tad on the lardy arse weight and not the ideal cradle for a BEC due
it using the whole Sierra rear end.
Pat...
Oh - Blade with modded sump & baffle plate, although I think they are fine with the standard sump.
Better clutch springs.
That's what I had and it was fine.
Pat...
Three replies all picking three different engines
Fireblade's switched to injection in 2000 with the 929. At least that is what is stated in the Haynes Fireblade '00 - '03. manual
Avoneer beat me to it...i think the cat is a bit on the heavy side for a BEC. Is the cat the one with the whole back end of a sierra bolted upto the
back end ?.....But if you do do it you wont go far wrong with a blade, zx9, R1 ect
Originally posted by mark.s
Avoneer beat me to it...i think the cat is a bit on the heavy side for a BEC. Is the cat the one with the whole back end of a sierra bolted upto the back end
have a chat with zxrlocost you prob find as well he could do conversion for your about the same cost you would get parts for see this thread click me
hi R1 carb engine no doubt about it Ive experienced most and my order goes ZX12r, R1 Carb R1 FI
its up there with the best due to its power vs simplicity
plus yes the car is heavier but no heavier than all the BEC mini driving about
Fit a sump baffle plate in a carb'd R1 and off you go. My stock clutch did 7000 miles of hard road and trackdays and I'm assuming it's still going strong! (the car is now sold....)
893 blade
Make your own baffle, easy, old enough to not require emmisons, good power to weight.
Cheap
Once SVA'd sell on and stick in a late engine if you feel its slow or bung on a turbo.
Originally posted by Avoneer
I'm sure it will be fine, but I was under the impression that the Cat was a tad on the lardy arse weight and not the ideal cradle for a BEC due it using the whole Sierra rear end.
Pat...
Thanks for the advice I had not considered the extra weight of the Tiger cat and it may well be an issue.
