any idea were i can find some?
its a c series carb.
If you buy a dynojet kit, you get new needles with the kit.
Al.
]Originally posted by larrythelathe
i have a kit fitted however i stripped down the carbs today and found one needle badley bent.
I didn't build em!!!!!!!!!
here maybe
http://www.allensperformance.co.uk/data-keihin%20jet%20needles.html
the ones i am after after are straight with no grooves
If they have no grooves, there not dynojet needles, sounds like stock ones to me.
Things are becoming clearer.
I have a receipt thats says cjk 001 tts kitcar jetting kit this would seem to be the main jets.
I am going to order some needles from TTS
what number grooves are you guys on for a starting point so i can drive it to the dyno?
I used the standard set up from Dynojet (4th groove from the top, you can get the set up from
http://www.dynojet.com/pdf/2185.pdf
Ian
