Hello All,
My IVA is this friday (15th of October, 2021) and I am wondering what I need to pack in the back of my estate for the big day.
So far I am thinking:
that's more than i took!
how about spare fuses and relays?
evidence of brake hose suitability - particularly from reservoir.
can you adjust the brake balance and lock it off again? mine was way off (due to pads not being bedded on reflection) but the examiner let me adjust
it at the test as long as it was within the time allowed.
the other thing i had missed was that the brake fluid reservoir has to be labelled, eg DOT 3, as well as the symbol shown in table 1, section 09D of
the IVA manual.
good luck!
Thanks for the tips!
Fuses and relays packed, brake and fuel hose suitability printed off.
My balance bar is locked off. I have used the car in events a fair bit and the balance was set pretty bang on. I span it one forward from there and
tested it at an airfield; fronts lock before rears. That was my locked position.
Brake fluid and balance stickers are on the car.
Nervous! I'm hoping for a first time pass but we'll see. The stars have to align and all that.
common failures include
rear reflectors
manufacturers plate
seat belt height
indicators and side repeaters
if you were to show us a few more pictures we could give it a 'once over'
I note from your avatar picture, that the front indicators may not be far enough out
also take some 'build' pictures with you just in-case they want any clarification.
Originally posted by G13BLocost
Hello All,
- Spare fuel (jerry can)
- Tyre pump and gauge
- IVA Manual
- Print outs and/or copies of all relevant paperwork
- Laptop (just in case I have to make an adjustment for emissions)
- Tapes, Glues, Trim and Tie Wraps
- Tools
What am I missing?
Josh
[Edited on 10/10/21 by G13BLocost]
In my SVA days the fuel tank had to be full.
(in my haste not to be late I fuelled at the petrol station outside the centre, over-filled and rolled up at the SVA test with fuel pissing out of the
tank! )
Spare lamps? One of my indicator lamps failed on the way to the test and I had no spares so failed on that!
(in my haste not to be late I fuelled at the petrol station outside the centre, over-filled and rolled up at the SVA test with fuel pissing out of the tank!)
Spare lamps? One of my indicator lamps failed on the way to the test and I had no spares so failed on that!![]()
Just a thought, Chassis number permanently stamped into the chassis and also a chassis plate with the car details on .
Both things i failed on my first visit.
Oops I forgot to say, GOOD LUCK and enjoy the test, they are mostly very nice people so always treat them that way whatever they say as it may be a
learning curve either way.
[Edited on 14/10/21 by Deckman001]
Passed
Passed![]()
Wahooo well done matey.
Excellent! Well done!
Which test station did you use?
Excellent, that’s where I’ll be taking mine. Hopefully soon!
Congratulations. Any feedback, hints or tips?
