Anyone used these instead of the usual alloy or steel versions?
Dodgy? Waste of time? Why would you? Opinions please?
Haynes Locost Roadster Orange steering rack Clamps in Duraflex Extreme Poly
I assume there is a steel bit to go over the top?
If not you might as well hold the rack on with a couple of rubber bands.
If not you might as well hold the rack on with a couple of rubber bands.![]()
"exceptional resistance to tear"
So they can tear then.. I would not be happy with that..
For our sort of cars, I'd be using a solid machined aluminium rack clamp, to get rid of the flexible bit (the bush), not getting rid of the steel bracket and making it all flexible!
I tried these, they don't really work. You still have to use part of the rubber bush between the rack and chassis mounts. Changed to solid alloy ones instead.
