Brake line clearance
Harquil1908 - 2/3/16 at 10:26 AM
[img]http://[/img]
[img]http://[/img]
Thoughts on this please chaps. On lock each way and just not sure about the flexible brake lines being so close.
rodgling - 2/3/16 at 10:51 AM
If it's clear throughout lock-to-lock range, I would think covering it with a bit of split rubber hose where it's close should be fine. Ultimately if you're not happy, get a new hose which doesn't come straight out of the calliper but has a suitable bend in the fitting.
HowardB - 2/3/16 at 11:35 AM
I have angled banjo fittings on mine, sets the bend in the right direction from the outset.
linky
hth
Oddified - 2/3/16 at 11:57 AM
I'd also prefer less fittings between flexi and the caliper straight in or a banjo to change direction.
Ian
adithorp - 2/3/16 at 11:58 AM
Well... the pictures are huge
Though they don't contack anything, I'd say the hoses are too long. You want them to just have a bit of slack/droop when fully extended; That means there's as little loop as possible to keep clear of anything when on lock the other way.
Angel Acevedo - 2/3/16 at 02:43 PM
Maybe too late now, but, wouldn´t be better to have the hose exiting right next to lower A-Arm?
Harquil1908 - 2/3/16 at 04:40 PM
I to would like the flexi cable to go straight in but the calliper is 1/8npt and the hose is m10. I don't really want to tap the calliper to m10 as I think there still under warranty as the were brand new when I go them but thinking it maybe the way to go and would look a lot neater.
