Morning all
I've bought some 13” minilite wheels for the westi, all have good tyres but are 175/70R13s. From a handling point of view is it worth swapping
for a 185/70R13, or even wider 205/60r13 to put more rubber on the ground? The car used 13" wolfrace alloys with 185/60R13 tyres previoulsy, so
I'm guessing that may have been for good reason. I'd appreciate any tips from you guys.
Lastest restore diary video which shows car progress
https://youtu.be/6nHKhV_sD2k
Thanks in advance
JK
[Edited on 1/4/18 by petroldiaries]
How wide are the minilights?
Also you need to remember the different tyres will alter the speedo reading,'will they fit.com' is a great website to work out how the
wheels will sit in your arches and it also gives you speedo difference and ride height difference
I would say with your XE power the minimum tyre size wants to be a 185/60.
Quite a popular set up on Westfields is 185/60 on the front and 205/60 on the rear,but you need a minimum wheel width of 6 inch to use a 205/60
I’m using 185/60/13 all round on mine with the new R888R tyres, very happy with it so far and still gives me a bit of rear end play when I want it.
That’s on a striker with a 130hp zetec
Great advice guys, will they fit is a great site. Thanks
The wheels I've bought are defo wider than 6" so I've got some good options.
JK
7" = 205/60/13
As you had 175/70/13 before they must have been stretched to fit, I suspect you have 6" rims so have a look on the back for sizing.
Originally posted by mark chandler
7" = 205/60/13
I bought some 6 x13 minilites and had a set of 185 & 205 R888’s the 205’s look a bit wide with the sidewalks sloping in to the rim
Cheers for the tips guys, any recommendation on tyre make. Is there a preferred choice, Yokohama were mentioned as a good choice but interested in any recommendations?
Nankang ns2r are a great road and track tyre for the money
Cheers mate!!!
[Edited on 9/4/18 by petroldiaries]
