Hi
Has anyone any experience with these: -
https://www.rallydesign.co.uk/product_info.php?cPath=1375_21
28&products_id=15408
Looking to get a second set of wheels for my MK. Currently running TD Pro Race 1.2 (but they're out of shape due to some previous mistreatment
when getting some R888's fitted!) and want something rounder before driving to Le Mans next month.
I'll be putting something like R1R's on, using them for road and wet track, then the other set will keep 888's on and get driven to the
canvas on track
is it ET38 your look for?
I might have a set on 7x15 alloys, if you u2u me your email i’d sent you
some pics chap
When I was searching for some new rims I found theses to be quite heavy, something to bear in mind.
Rally Design say 6.6kg. I believe Pro Race 1.2 are about 6.2kg, so they are heavier but not massively so?
13" Pro race are only 4.5kg....just saying
Originally posted by peter030371
13" Pro race are only 4.5kg....just saying![]()
Wonder who manufactures them,could well be made by Rimstock/TD.
If they are Chinese manufactured I can't see the weight being that close to a Pro-Race 1.2 tbh
So went for them in the end. They look good to my eye, and weigh 14.7kg per corner with new Yoko AD08R vs 14.9kg for my Pro Race with part worn R888, so whilst I expect the 888 are made of more rubber, the final setup is actually comparable so a good road/wet setup against the Pro Race/R888 combo for dry track use.
